查看: 19067|回复: 0
关于Selecto的部分介绍:WQA Goldseal
发表于 2011-12-1 19:46 | 显示全部楼层 |阅读模式
Selecto's Water Filtration systems are assembled and inspected by trained technician, not on an assembly line.  Each step in the assembly of your water filter is done by hand and documented.
Are you impressed by the slick websites and shiny filter cartridges?  Selecto invests in your water quality instead of marketing glitz.  When you do your research, you find Selecto leads the industry.
Many people spend literally thousands of dollars on "water filters" that are no more than water softeners (conditioners) dumping salt into their water.  They don't remove chlorine, chloramine, disinfection byproducts, VOCs, or many other dangerous contaminants!  They also have a very negative environmental impact due to the backwash of salt into the environment.  If hard water is a problem for you, you can install a green sand filter ahead of our Contamin-Eater to make your home as happy as you are!
Efficiency
Selecto water filter superiority is largely due to their patented Hollow Carbon Technology.  It's just plain BETTER than the activated carbon and carbon block used in other water filters.   Take a look.
  Selecto's SMF System removes over 99% of water contaminants.
  Only system that provides high capacity (50,000-300,000 gallons) chlorine and/or chloramine removal.
  Provides high flow rates with nearly zero pressure drop.  Competitive brands drop 8 - 10 psi.
  Lasts about 10 times longer than traditional carbon filters.
  Efficient media means a smaller size filter.  Easily fits into a crawl space or laundry room wall.  No need for a tank the size of a man!
  Tested in accordance with NSF standards  42 & 53
  Comes with a 100% performance guarantee!
Convenience
  So ez to install many people can do it themselves
  Modular design makes this the most adaptable filter choice.  Every filter head fits onto every cartridge size (10', 14" or 20") so as your needs change, the size cartridge you choose can change.  You can even reduce the number of filter heads you use.
  Sanitary Quick Change cartridge means no messing in toxic media or service calls to make.
  Cartridge changes are so ez it doesn't even require tools!
Tested, Approved
Contamin-Eater Whole House Water Filters and Legacy Point-of-Use Water Filters by Selecto are commercial quality, serious filtration systems.  They're not shiny, and this isn't the slickest web site you'll ever see, with the prettiest graphics (though we do try, and most people love our bubbles!) Our customers are the ones who do their research. They really care about the Health of their family, protecting their investment in their home and appliances, and are determined to find the best quality available.
* The Commercial "SMF IC" Series is the same as the Residential Contamin-Eater Series.
* The Commercial "QC" series is the same as the Legacy Residential Series.
Selecto is not some off-shore sweat shop pounding out product.  They're right here in Georgia, USA, and they're not only a manufacturing facility - they're a scientific laboratory - constantly testing and innovating.
Made right here in the USA!
Both ezClearWater.com and Selecto Scientific, Inc. are located just north of Atlanta Georgia.  You help keep and create jobs right here where we need them!
GMT+8, 2026-1-12 03:14 , Processed in 0.066210 second(s), 18 queries , Gzip On.
